Originally Posted by alpinelakespilot2000
I am referring to the plain old aft deck (the one that goes over the aft-most 3 bulkheads).
Yep, there's a gap. The most important things here are alignment and edge distance...alignment so the F-709 (I think that's it) semi-circular bulkhead is in the right spot, and edge distance so the holes you drill through the longerons have at least 2D all around.
FWIW, some photos of mine:
(see the gap all around? yellow...green primer showing through...)
