Old 04-25-2011, 08:51 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Define "slight drag" ?
"SLIGHT DRAG" with reference to wheel nut tightening.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 04-25-2011, 09:04 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Less than SIGNIFICANT DRAG.
Old 04-25-2011, 10:00 PM
flion's Avatar
flion flion is offline
A skinny guy in women's clothing?
EAA Technical Counselor #5357
Old 04-25-2011, 10:51 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
Spin the wheel by hand and it goes round a couple of times before stopping.
Old 04-26-2011, 01:06 PM
Andrew M's Avatar
Andrew M Andrew M is offline
Default Wheels,
There is a way to quantify how tight the wheel bearings should be. The Caravan manual has you hang a weight on a string hung over the front tire and adjust the axle nut until it the wheel just starts turning. Other ways have you go to a minimum torque and tighten to the next safety.
Now how 99% of the mechanics actually do it. Spin the wheel with the bearings loose and tighten the nut until you think all the slop is taken up. Beat the tire a few times from the side while placing your finger on the axle and wheel to feel for any looseness and to make sure that everything is seated. Tighten to the next safety, and cotter pin.
Andrew Miller
A&P, IA
-9 empennage
Wings arrived 12 JAN 13
https://plus.google.com/photos/11360...J-TuJPsmOONzQE
Old 04-26-2011, 07:02 PM
gasman gasman is offline
If you are talking nose wheel, it has it's own issues with the wheel form Van's. Best to do a search on nose wheels.
Old 04-26-2011, 07:05 PM
That drag after no drag and tightening the nut just far enough to get a cotter key through it.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Geico266's Avatar
Geico266 Geico266 is offline
A slight drag is when my X walks into the room, a significant drag is when she starts talking, no drag is when I get up and leave.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
