Go Back   VAF Forums > Main > Reviews
Old 04-25-2011, 07:29 PM
Brantel's Avatar
Brantel Brantel is offline
Default Installed Janekom's fairings. He is the real deal!
Since I go in for paint on the first of June (Bobby Potts) I took a chance and ordered Janekom's fairings that he has been advertising here on VAF.
Let me just say that he is the real deal and I got just what I paid for in about 7 days from South Africa.
His fairings are ready to mount and paint. The finish is awesome out of the box. No pinholes!!! I only had to do some minor sanding back of the trailing edge in order to get the bottom half to align perfectly with the top. Other than that, what you see is what you get, easy peasy!
I had previously installed Van's intersection fairings on the top but the bottoms were unusable without much much work so I never did even try to mount and repair them. The ones for the top that I got from Van's fit pretty good after much trimming but they were very very rough.
Anyway, I mounted up the ones I got from Janekom today and I am pleased with the product. His price delivered to the USA is very competitive.
Here are more pics if you are interested.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-25-2011, 07:39 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
They look great! Does anyone know if the RV-9 and the RV-7 have the gear legs coming down at the same angles? I know the -9 gear legs are significantly longer, but if they are at the same angle the -7 fairings should work. Last he mentioned, he didn't have a RV-9 to use as a model, but does he need one?
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 04-26-2011, 06:04 AM
Brantel's Avatar
Not sure. My guess is that because they are longer, to get the wheels in the right place, they must have changed the angle in order to do that. I may be all wet though. Van's might be able to answer this question.
Van's does sell different part numbers for their intersection fairing "starter kits" that they sell for the 9 vs the 7 so this also points to them being different.
Van's set are $146 less shipping and all you get is a rough, thin, oversized bunch of parts that don't fit well at all and which must be massaged into working, trimmed, extra layers of glass applied and then filled. Van's should take these off the market!
Janekom's fairings were $175 delivered in a week and are ready for paint out of the box and they fit pretty darn well.
Others are $300 plus shipping. Very good reviews from most.
Another brand is $230 plus shipping. Have not seen many reviews on these.
The two mentioned above are of the bond on type that require fairing in and final filling. These do look very nice but require more effort.
Old 04-26-2011, 06:54 AM
I am replacing the upper fairings and ordered from Jan this morning. They do look great. Thanks for posting the images.
Its time my 8 year old beast but on a new look, I guess you could call it a face lift.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 04-26-2011, 07:10 AM
Webb's Avatar
Webb Webb is offline
Would you show a picture of how you put a nut or nutplate on the back of the upper fairing for the screw that I see.
Thanks. Oh, and they look very nice. Much nicer than the hours I had in getting mine paint ready.
Webb Willmott
Jackson, MS
N32WW
Old 04-26-2011, 07:21 AM
cjensen's Avatar
cjensen cjensen is offline
Excellent report Brian! I have mine from Jan ready to mount...they are exactly as you've stated.
I am curious about how you mounted the upper one's as well. I was planning to use rivnuts...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 04-26-2011, 07:40 AM
Brantel's Avatar
I forgot to take a pic Chad... I used the existing nutplates that I put in when I mounted the Van's starter kit version of the uppers.
There is one in the cowl, one in the middle of the fairing and one back near the rear of the fairing. The are all on the bottom flat surfaces. I just crawed down in there and put the nutplates in. I had the fairings held very tightly to the fuse when I drilled the location holes. These really seem to hold the fairing well but I might have to add just one screw on the side later if they start to droop away from the side of the fuse.
Old 04-26-2011, 07:45 AM
Brantel's Avatar
Webb,
I will take a pic soon. I forgot to take one of this area.
Currently I do not have anything other than a nut. I really don't intend to keep it this way but I have not found the right solution for this. I think a modified "T nut" might work.
Or something like this:
If all else fails, I will get some low profile nuts and cut the screw off. It is not ideal but what else can be done about it???
Old 04-26-2011, 10:21 AM
Strasnuts Strasnuts is offline
Default RV-10 Fairings
I installed Jan's fairings on my ten. They fit nice and were easy to install. I epoxied my wheel fairings to the wheel pants and split them so they come off together. A lot less finishing work needed on Jan's vs. Van's before paint.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
Old 04-26-2011, 11:18 AM
Vlad Vlad is online now
Sean,
Could you please illustrate the split? Did you just follow the lines where halves are joined?
