Old 04-25-2011, 03:02 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default 5/16 shoulder bolt on gear
What torque did you use on the 5/16 socket head shoulder bolt that hold the brake mount bracket on. It had 1/4-20 threads according to the plans?
Looking on line Grade 8 1/4-20 steel bolt looks to be about 100-120 in lbs depending on the source I looked at.
The plans don't specify a setting, and this is no AN hardware.
Thanks.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 04-25-2011, 10:36 PM
GAHco's Avatar
GAHco GAHco is offline
Post Typically
Typically shoulder bolts are primarily Shear Fasteners.
AC 43-13 shear values for the thread size should probably work well.
Remember to add the friction torque to the value if using a locknut.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 04-26-2011, 03:04 PM
Flying Scotsman Flying Scotsman is offline
Being a dork, I initially torqued these to the specs for a 5/16ths bolt. I realized that was way wrong when it goobered up the washers. A call to Van's confirmed that it should be torqued for a 1/4-20.
Only cost me a few bucks to replace the bolts (which were *probably* okay, but I didn't want to take the chance).
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 04-26-2011, 06:02 PM
RVG8tor's Avatar
Default Thanks all
What you all suggest is what I ended up doing, funny I am not patient enough to wait. But I figured the torque for a 1/4-20 course thread was so low it would not hurt anything, now to mark the nut.
She is standing now!
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
