Old 04-24-2011, 02:45 PM
Mark L Mark L is offline
Default course thread stud - torque
Can someone post the torque value for 3/16" and 5/16" course thread studs. These would be for mounting the prop governor and the SD-20 B&C Standby Alternator on the accessory pad (in my case).
Mark Lancaster
RV-7A N530L Finish Kit
Old 04-24-2011, 03:47 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
I think what you're looking for is in this table from AC43.13:
Thanks, Bob K.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
Old 04-24-2011, 04:22 PM
Thanks Bob but I think these are rather classfied as engine studs and are torqued to higher limits and fall somewhere around 200 in lbs for 5/16, but I am still unsure.
Mark Lancaster
Old 04-24-2011, 04:38 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Can't help you directly, Mark, b/c I'm not sure about that pad, but you are correct that engine studs are often torqued to a much higher spec than 43.13. The carb attach studs are one such place and were, I think, 200 in-lb. If I remember correctly, someone pointed me to a Lycoming manual and/or something at Sacramento Sky Ranch.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 04-24-2011, 04:48 PM
Walt's Avatar
Walt Walt is offline
BOLTS, SCREWS AND NUTS (from the Lyc manual)
10 (3/16) = 49 in/lbs
1/4 = 96 in/lbs
5/16 = 204 in/lbs
3/8 + 360 in/lbs
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-24-2011, 04:49 PM
rzbill's Avatar
rzbill rzbill is offline
Default Need to use the Lycoming Specs
Mark,
I'm travelling and don't have these readily at hand. I got the Lycoming document from a post here on VAF. I think it was from Gil but maybe Mel.
Do a search and I think you will find the right doc. The studs you are using will be in the section on standard torques. There is a considerable listing of "special" torques, but the two pads you are fiddling with are not included in the special section.
I can attest that the Lycoming torque values will make your sphincter tighten up after being accustomed to the light AN values. I know $$ signs danced before my eyes while I was installing the prop governor. Its OK, they really mean them to be that tight.
EDIT ** Thanks for helping my neighbor, Walt
Bill Pendergrass
ME/AE '82
Old 04-24-2011, 10:05 PM
az_gila's Avatar
az_gila az_gila is offline
Originally Posted by rzbill View Post
Mark,
Probably one of my posts. From the Lycoming overhaul manual - note the bit on lubricating the threads, unlike airframe bolts.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-25-2011, 11:58 AM
chipf chipf is offline
Default Watch out!
The table that Gil attached shows 204 in/lbs for bolts, but it's not clear if it applies to Lycoming exhaust studs, which are 5/16-18 on my O320-E2A. I used this number, which I found in another post a while back and now have the pleasure of installing Heli-coil repairs on at least one exhaust stud.
Larry Vetterman's page recommends a much lower number, 140 in/lbs, and that's more in line with the data that Bob K attached.
Chip Freitag
RV-9A N207LT
680 hrs
cfrv9aproject.blogspot
Old 04-25-2011, 04:44 PM
Walt's Avatar
Exhaust stud torque is listed under "Special Torque Requirements" section:
5/16-18 Exhaust Port stud = 40 in/lbs min.
Old 04-25-2011, 06:56 PM
az_gila's Avatar
Is that for putting the stud in, rather than the nuts?
The exhaust system is usually an airframe item on a certified plane, so I checked my Tiger Maintenance Manual which gave 110 - 130 inch pounds for the exhaust flange nuts using new star lock washers - fitting in with the previous Larry Vetterman number.
Gil Alexander
