Old 04-24-2011, 09:40 AM
boom3's Avatar
boom3 boom3 is offline
Default Typical Fuel Pressure?
Wondering what kind of fuel pressure I should expect.
I have an IO-360B1B with Precision Siverhawk servo and Airflow performance electric fuel pump.
Typical setup per the plans, Dynon fuel pressure tranducer line connected to the "T" on the output of the mechanical fuel pump.
I seem to be getting between 10 and 11PSI with the engine running and the electric pump running. This is pretty consistant even at full power.
Thanks!
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 04-24-2011, 10:13 AM
boom3's Avatar
I found some good info here. I need to make sure my D120 is setup correctly as mine does seem to be too low.
http://www.vansairforce.com/communit...=fuel+pressure
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 04-24-2011, 10:17 AM
Walt's Avatar
Walt Walt is offline
25 to 30 psi is normal for a FI engine.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-24-2011, 10:29 AM
boom3's Avatar
Thanks Walt.
Looks like I just need to change the sensor type in programming to "injected" as it's probably still on the default of "carburated".
I'm pretty sure that is the problem. My Bad!
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 04-24-2011, 10:37 AM
Bavafa Bavafa is offline
I get a steady 23-24 PSI with just the mechanical fuel pump and when I turn my electric pump , it goes to 32-33 for a few seconds and settle down about 27 PSI.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
