When the electric boost pump is running without engine
it developes pressure up to the pressure relief valve setting and then starts recirculating. The pressure on the inlet side of the mechanical pump will be the same at this point. Once the engine is started the mech fuel pump inlet pressure will decrease as fuel flow increases. At full power on climbout(max operating conditions)if your boost pump outlet pressure was indicating less than 14 psi that may indicate you have faulty pump or a restriction in your fuel lines/filter/screen before the pump. If your mechanical fuel pump quit pumping you want to have adequate flow/pressure from your electric boost pump to keep the engine running until you can land. Lycoming does not know what boost pump set up we use. I am trusting that Van's has already tested my setup since I built per the plans. If one deviates from the plans one may want to measure these pressures before flight. The mechanical pump on the IO-540-D4A5 can have a minimum inlet pressure of -2 psi. By setting the minimum outlet pres at 14 psi this gives us some margin to guard against vapor formation and lets us know we have a properly sized boost pump for our engine, especially if the mech pump goes out.
Good judgment comes from experience, and a lot of that comes from bad judgment.
