Old 04-22-2011, 08:06 PM
Tram Tram is offline
Default Intercom near wet compass?
Just curious if this would cause any issues with the wet compass?
I can't imagine the compass interfering with the intercom, but just curious before I started drilling holes.. LOL..
Old 04-23-2011, 01:00 AM
jimgreen jimgreen is offline
Jeff, my compass is about 1" from the intercom(pm1000) and does not cause a swing in the heading. Transmitting on a comm radio does cause about a 10 degree swing in my set up. That doesn't matter too much to me since it is a brief and occasional thing. I experimented quite a bit with compass position but in the end had to compromise. I only pplan to use the whisky compass if my Dynon fails! Would not have installed it at all but my Canadian inspector requires one.
Good luck.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
Old 04-23-2011, 07:19 AM
Kinda what I was thinking..
Old 04-23-2011, 07:48 AM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default Better compass
If you install a precision PAI-700 vertical card compass all compass errors will be reduced around 80% and you get a superior presentation without the backward reading to boot. Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
Old 04-23-2011, 08:52 AM
I think we will leave the compass alone.. We don't do hard IFR in it, I still know how to follow roads..
Old 04-25-2011, 10:05 AM
By the way, if you place the compass low down, forward movement of the stick gives a pretty wild heading swing! That rules out IFR aerobatics.
Jim Green
RV7 tip up
Old 04-25-2011, 05:07 PM
Good heads up.. Compass is mounted.. Intercom is not..
Working on a lil' retrofit activity..
