Oil cooler shutter gasket
I'm installing the oil cooler, and have the Van's oil cooler shutter all riveted in and everything. The only small problem, and it's fairly small, is that I have to insert thin (960-10L) washers between the cooler and the shutter, or the "fins" on the cooler interfere with the shutter. So, simple question...
Any recommendations on some sort of "gasket" or RTV to use between the two, to make an airtight seal? Or is it even needed (it's a very, very small gap)?
TIA!
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
