Old 04-22-2011, 09:45 AM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Grease or oil gear sockets
On final assembly did you use grease or just oil up the parts of the leg that go into the socket. I would think grease would be getter for long term corrosion protection. There are no grease fittings to intro duce grease here on a regular basis.
Would a light coat be better if too much grease does it ooze out over time? These are things a new builder ponders when the directions give no direction on such matters. Grease oil, heavy light Aeroshell 22 or lithium what to do what to do!
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 04-22-2011, 09:50 AM
kentb's Avatar
kentb kentb is offline
Default I just asked that question....
I talked to Harmon Lange a couple weeks ago (the guy the makes all the gear legs for Vans). I asked him about when I reinstall my gear leg, if I should put some grease in there.
He told me to just use some anti-seize when I install the legs.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 04-22-2011, 10:16 AM
RVG8tor's Avatar
Default Anti-seize
I had not thought of that one, you can't get any better information than from the guy that makes the parts.
I have read a lot of posts and have heard everything from lightly oil to heavy grease.
I don't have any anti-seize looks like a trip to the store, any recommendations on what type to use?
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 04-22-2011, 10:55 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
http://www.sealanddesign.com/categor...nti_Seize.aspx
Lots to pick from.
I would think something with graphite would be good. It should still provide some lubrication after the petroleum base dries out.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-22-2011, 11:29 AM
RVG8tor's Avatar
Default Weath of Knowlage
Thanks Mike certainly a lot to choose from.
Lots to pick from.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 04-22-2011, 11:39 AM
gasman gasman is offline
Just get a tube of it for spark plugs...... you will be using a very thin coat. And you can also use it on your spark plugs.............
Old 04-22-2011, 11:40 AM
rocketbob's Avatar
Last summer I took the gear legs out of my RV-6 to weld cracks in the engine mount. I was amazed at the amount of rust/pitting on the leg where they are tapered inside the sockets. So I would make sure its primed and only areas where metal to metal contact occur that you don't prime and I would use a good nickel based anti-seize there.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 04-22-2011, 11:54 AM
Walt's Avatar
Walt Walt is offline
This is what I would use if I was buying something specifically for this purpose (IMO antisieze is not appropriate in this application).
AEROSHELL Grease 17 is a fully synthetic grease containing 5% molybdenum disulphide. It is particularly suitable for lubricating heavity loaded sliding surfaces such as bogie pins on aircraft landing gear assemblies over the temperature range of -73 ?C to +149 ?C.
Fact is, I just used Aeroshell 22 that I use on wheel bearings:
AEROSHELL Grease 22 is a fully synthetic grease designed for severe operating conditions including high bearing loads, high speeds and where long grease retention and high water resistance are required.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-22-2011, 12:23 PM
Auburntsts's Avatar
Default What Van's says....
As a data point, the RV-10 plans specifically state on the gear installation step to "apply a film of wheel bearing grease to the surfaces of the main gear leg that are not powder coated and that will contact the gear mount socket." YMMV....
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
