I assembled my main wheel and brakes, I am using the Grove wheels and did not order the Cleveland stuff from Vans and the drawings I did get are not real clear.
I installed the brake caliper support on the outside of the powder coated support that Vans has in the kit, can't remember the part number off hand but you will see in the picture.
The picture is a shot showing the parts. The outside pad is just off the disk and the studs and go into the caliper support are sticking out just a bit on the other side. Do I have this correctly set up?
Anyone with the Grove wheel and brakes please let me know if I have this set up correctly. I did have to trim the pant bracket so the caliper would clear it. Oh I know there is a missing bolt, this was temporary and that one was not need to do the fitting that I was doing.
As always thanks.
