Old 04-21-2011, 03:17 PM
tclaire tclaire is offline
Default tach cable maintenance (Lube)
What is the best lube to use in the tach cable?
Tim
Old 04-21-2011, 03:31 PM
Walt's Avatar
Walt Walt is offline
Tim
Dry Graphite
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-21-2011, 03:47 PM
Originally Posted by Walt View Post
Dry Graphite
Walt what is the best (less messy) method to put that dry lubricant in? Without disassembling of course. There is some sort of grease in there.
Old 04-21-2011, 05:37 PM
Walt's Avatar
Hmm... Graphite is messy no matter what, pull the cable out wipe it down with a rag and start feeding it back in while adding the powder to the cable between your fingers. Not nearly as bad as pro-seal
