RV-8 static system port
Goodmorning all,
Well here it goes....another "ooops" I screwed up again. I drilled and installed the pull rivets for the static ports in the wrong place from not reading the instructions correctly. They were installed next to Bulkhead 808 instead of 809. I was referring to the picture illustration (RV-6) that came with the kit, and didn't referr to drawing 41, as I should have....daaah!
Question: anyone know if this will significantly alter function/accuracy at this location? It wouldn't be difficult to redo, if this location is less than optimal.
