04-18-2011, 05:51 AM
Oil Cooler size for IO 360 A1A 200hp
I had planning on going with the larger oil cooler size for my 200 hp engine based on other forum discussions. But before I bought it I thought I would ask to those who have the IO 360 A1A, do I really need the bigger one and the headache of trying to fit it or is the standard smaller cooler suffice?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
04-18-2011, 07:38 AM
Hi Ryan,
If you think you may need it, why even bother putting the smaller one on? I didn't think I would, but I did...and mine is just a 180 hp O-360. Fitting a 10-row cooler wasn't bad at all.
Sonny W
Boise, Idaho
RV-7A Flying!
04-18-2011, 08:16 AM
The angle-valve IO-360 is guaranteed to overwhelm a standard Vans small 7-row NDM oil cooler in a dramatic way. If I remember correctly... all angle-valve Lyc IO-360s have piston oil squirters which raise the amount of heat absorbed into the oil by a large amount. Most 200hp angle-valve IO-360s I've seen on RVs and Glasairs have used the big 13-row oil coolers along with some kind of air valve for restricting the airflow in the wintertime. On a -7 the physical fit will be very tight, so if you haven't yet started mounting stuff onto the firewall and routing cables thru it, etc, now might be a good time to reserve some firewall area for possibly mounting an oil cooler there and running a scat duct over to it.
We went thru quite an ordeal with oil coolers with a high-compression parallel-valve ECI Titan IO-360 in an RV-8 and would've saved a lot of headache if we'd just put a big oil cooler on to begin with. Now we have the SW 10599R and it is proving to be just the right adequate/nominal size for our engine.
Neal Howard
Airplaneless once again...
04-18-2011, 09:23 AM
04-18-2011, 11:45 AM
what's on the side of your oil cooler
Gary - is that a heater or a thermocouple on the side of your oil cooler? Also, have you tried your system with and without the duct directing the hot air down? I'd love to know how effective that is.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
04-18-2011, 02:02 PM
Big cooler, firewall mount
I have the same engine, and in the summer, you really want the big cooler. I installed mine on the firewall, with a plenum mount similar to the one Van sells for the RV-10, but with different angles to nest well in around the engine mount on the RV-8. I used a 3.5" scat hose from the #3 baffle, with a butterfly valve in it that is cockpit adjustible. If I had it to do again, I would use 4" scat. You can buy a 4" butterfly valve from.....
http://www.nonstopaviation.com/rv10-...r-p-14566.html
I find that in the fall-winter-spring, I set the valve closed about 60% to get 180F oil temp. In summer, it is wide open and stays that way.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
04-18-2011, 04:23 PM
It's a 25watt heater that is also part of a 100 watt heater on my oil sump, works well. I have tried the duct without hose, with a hose right down to the exit air opening and what worked best for me was to compromise. I have a 4" skeet tube( smooth interior) directed straight down then a 45 degree angle on it just to direct it toward the exit air opening. I believe it was less friction of the full pipe and the better direction other than straight down that had the best result for me. I also gained 40 kts
If I can find a pic I will post it later.
pics found, here they are
Reason: added pics
04-18-2011, 06:17 PM
Thanks, all...good info. Looks like I will go ahead and go with the bigger cooler. Now which one, Aero Classic, Positech, SW, Airflow Systems...that's another debate.
Steve any chance you have any pics so I start getting some ideas on mounting mine.
Matt Dralle came up with a very nice set up on his 8...I will look into tonight as to whether this would fit my 7 tonight...don't see why it wouldn't. ??
matts pic.
Ryan Allen, CFII
E-170/175
04-18-2011, 07:00 PM
Be careful, the 8 has a different angle to the engine mount tubes that makes mounting a wider oil cooler on the baffle an easier proposition compared to the 7 ("easier" being a relative term when discussing anything related to the baffles!). Of course, the 8 has its own complications related to vertical placement of the oil cooler, due to the cowl shape. Basically there's no perfect place so you just have to make do with whatever you can squeeze in there.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
