Old 04-17-2011, 06:28 AM
auflauf auflauf is offline
Default 320 most economic fuel flow?
Hello!
Actually, I am narrowing down the list of potential planes. Fuel consumption is a major concern as fuel prices are high here in Europe (e.g. Avgas 14$/usg, Mogas 98 oct 9,2$/usg).
For some xy-320, I found the fuel flow for 75% power setting being given to ~8.5gph. This equals to 118$/h for 100LL
Do you have any experience with lower power settings (55%, even lower)? Is it possible to fly a xy-320 with 6 gph or even 5,5 gph?
Thanks!
Alexander
Old 04-17-2011, 07:16 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Absolutely - just pull the throttle back for whatever fuel flow (and resulting speed) that you feel comfortable with. I can pull the power back on my O-360 to just what I need to stay airborne in the RV-8, and the fuel computer will show me with about an 11 hour endurance (or some silly number).
It's hard not to let an RV run though - but that's a pilot discipline issue...
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-17-2011, 07:21 AM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Default Long term effects
I have some experience flying along with a Cessna 150. The very low engine temperatures made me wonder if doing this for a long period of time might have adverse effects.
I have never heard of anything bad, but as Paul says, it is kind of hard to make oneself do this for a long time.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 04-17-2011, 07:25 AM
Capflyer's Avatar
Capflyer Capflyer is offline
On my RV4, O320 160hp, at 24sq which is about 75% and aggressively leaned I cruise around 7.5gph. I have the Electroair electronic ignition which made about a 1/2 gph difference in my fuel consumption for cruise flight after I installed it. I am able to run about 25deg LOP now with the EI and my fuel consumption drops to around 7gph and gives me around 150kts IAS at 5000'.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 04-17-2011, 07:39 AM
Snowflake's Avatar
My O-320 150HP RV-6 cruises comfortably at 170mph and 25-27 L/hr. Conventional ignition (mags) and fuel metering (carb). That's at 2350RPM, roughly, but I don't know the MP as I only have a fixed pitch prop.
Rob Prior
Old 04-17-2011, 07:40 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Same here with my 180HP 6A. Fly's, but temps are too low for my liking.
L.Adamson --- RV6A
Old 04-17-2011, 08:35 AM
jmbrwn's Avatar
jmbrwn jmbrwn is offline
Rob- I have the same set up as you, and last year flew to OSH at 10,500' average at 2400 rpm and got 25 liters/hr (6.6gal/hr) @ 170mph. I'm turning an Aymar Demuth prop...what prop do you have?
Jim Brown
RV6, Christen Eagle II(Sold)
ATP, CFII, A-IGI, A&P/IA
Carrollton, GA
Lyon?s Landing
Old 04-17-2011, 09:18 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Some basic concepts
1. A fuel injected engine can be run well lean of peak while a carb engine usually cannot. This represents a large fuel savings for a given power. Even a FI engine may require balancing the injectors.
2. A more efficient prop will save fuel. In theory, a C/S prop can be more efficient, especially over a large range of power and speed settings. You can run a C/S prop at open throttle, reducing, thus, pumping losses, even while at lowered prop speeds. Within the range of C/S props, the MT series appears to be less efficient than Hartzell or Whirlwind RV 200. This is second-hand information. For a given speed and altitude, a FP prop can be just as efficient as a C/S prop, but probably not over a wide range of performance.
3. As noted above, you burn less gas if you slow down. For a distance traveled, your best L/D speed is the most economical. The RV-9 is the most economical RV that I know of for mpg or litres/100 km. See the CAFE test on that. The best compromise for speed vs. fuel is the Carson's speed. Look it up or see my info page, linked below. This is really about the drag curve, not about the engine.
4. Also as noted above, you can reduce fuel consumption per hour to even less if you go even slower, but your fuel per distance goes up. That would be the minimum sink speed and it is roughly 76% of the speed for best distance (L/D) while the change in fuel per hour will be roughly -14% from best L/D.
5. In my experience with my io-360, best performance from the engine will not be reached at very low power settings. RV's are fast not only because they are slippery but because they have a lot of power compared to other planes. If you know you don't want to go fast, just inexpensively, a smaller engine may work out better for that reason.
The engine is designed to be used at power settings above 60%, I think. I can fly mine at 35%, for example.
6. Also second-hand information: electronic ignitions seem to give some added fuel economy when used running lean of peak.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 04-17-2011, 11:15 AM
That's exactly what I was suspecting: you may be able to use low power settings, but it is not "practical". Like in a car, there may be throttling losses. But the information given further up, that 6gph may be realistic, at least does not rule out a 320 from the start.
My ideal plane might be a MC100 (the all-metal precessor of this one: MCR01) with a slightly beefed up structure. But they are hard to find - and the composite ones are said to be rather fragile
Old 04-17-2011, 02:00 PM
hevansrv7a's Avatar
Default Very realistic
Yes, 6 gph is very realistic even for a 360. It may be a little less efficient than at higher settings but it will do it easily.
