Originally Posted by SkywayCaptain
The FAA will not have a problem with you flying VFR without a flight plan if you remain within US borders. I am not sure what Transport Canada would think about it. Maybe you should ask them.
What about a Canadian aircraft operating night VFR without a flight plan within the US??
Here is a link to an FAA document for the Operating Limitations for Canadian Aircraft operating in the US.
http://www.copanational.org/files/FAASFACanadianABA.pdf
Number 8 says:
8. The aircraft shall be operated under visual flight rules (VFR), day only, unless the operating limitations issued for the aircraft authorize night or instrument flight (IFR) operations, in which case the aircraft shall be equipped in accordance with 14 CFR part 91.205 and the pilot in command shall comply with 14 CFR part 91.711.
The above is very similar to what Canada requires of US Amateur Built Aircraft or was the last time I flew my RV-6 to Canada.
