Old 06-05-2011, 03:35 PM
Mel's Avatar
Mel Mel is offline
It's not unusual for one wing to be a little heavier than the other, but 20 lbs. is quite a bit. I think I would investigate. Are you sure the left tank is empty? Nothing laying on the left wing? Aircraft laterally level? Only left half of a heavy interior installed?
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-05-2011, 04:45 PM
Greg Arehart's Avatar
Mel,
I agree and have been scratching my head on this one. The only differences in the wings that I can think of are that the L wing has the AP servo, pitot/AOA assembly, and an Archer antenna in the wingtip. R wing has the camera setup (about the same location as the AP servo on the L wing) and an APRS unit in the wingtip. And yes, both tanks were drained. Interior is spartan and symmetrical. I can't think of anything in the engine compartment that would cause this. My battery is on the R side of the firewall. There must be something that I'm missing..... When it had nose gear, the weights were L 435 and R 437.... Maybe I should swap the scales (L & R) and see if that gives me the same numbers - could be something to do with the scales, but they were just calibrated a couple days before I used them.
greg
Greg Arehart
N 7965A
Old 06-05-2011, 05:20 PM
wil's Avatar
wil wil is offline
Greg, are you sure one of your rockyology students didn't sneak into your hangar and put a piece of fubarite in your wing tip?
Wil Heslin
Groveland, CA
RV-7 empennage, wings
N229WH reserved
Old 06-05-2011, 06:51 PM
Ok, the only thing I could come up with that makes sense is that the tailwheel maybe wasn't perfectly straight. If it were cocked to the right, that would shift more of the overall weight to the L main. Would that be sufficient to cause the 20 pounds difference?
A quick calculation on the center of gravity indicates that the lateral CG is about an inch left of center. If I assume that the TW was off-center by 4 inches (probably at or beyond the limit of reasonability), the calculations show that to end up with the same CG, the weights can only change by a couple of pounds. Therefore, I conclude that having the TW cocked cannot reasonably account for the difference in weights that I measured.
So, after an hour of figuring on this, I still don't know why the difference in weights, other than 1) some sort of unknown weight on the L wing (fuel? but I'm pretty sure I drained the tanks completely - nothing was drooling on the hangar floor when I got done); or 2) a scale error. It would require about two gallons of fuel in the L tank to cause the problem I'm observing.
And I'm pretty sure there is no fubarite in the wingtip.....
greg
Greg Arehart
N 7965A
Old 06-05-2011, 08:49 PM
chipf chipf is offline
greg
Slight geometry problem with the new main gear?
How much did it weigh as a nose dragger? Can you account for all the difference?
Chip Freitag
RV-9A N207LT
680 hrs
cfrv9aproject.blogspot
Old 06-05-2011, 09:21 PM
Chip,
I don't think there is a geometry problem (flies and ground tracks nicely). In addition, I can't see how a slight shift in gear position would drastically affect the CG. If my calculations are correct, the wheel position would have to shift by about two inches to cause the apparent difference in weight. As I write this, however, I am thinking of how the airplane was weighed and may have an explanation. I did not roll the airplane up on the scales, rather, I picked it up with a hoist and set it back down. When one does that, the gear springs downward. Then upon lowering the airplane, the lateral friction from the tires keeps the gear from spreading fully. The total weight is probably ok, but it may be that one leg or the other (or both) is geometrically off and could account for as much as a couple inches. Hmmmm. Guess it would be good to try the reweigh and see what happens. Thanks for the prod to think about this in a different way (weigh).
I have not tried to account for all the differences due to the changeover. I don't know the weight difference between all the different gear legs, tailwheel parts vs. nosewheel parts, different engine mounts, removal of the "A" gear towers, etc. I did lose 25 pounds overall.
greg
Greg Arehart
N 7965A
Old 06-05-2011, 09:22 PM
N941WR's Avatar
N941WR N941WR is offline
Did you check the scales before you weighed your -9?
I typically stand on each scale before we roll the plane on them, just to make sure they are all within a pound or two of each other.
Just because a scale is "certified" doesn't mean it is accurate.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-05-2011, 09:28 PM
Bill,
Good thought, though these were literally just back from calibration so one would assume that they are correct within a couple pounds. I did not, however, check them. I'll add that to my list of checks for the reweigh.
greg
Greg Arehart
N 7965A
Old 06-06-2011, 01:18 AM
rvmills's Avatar
rvmills rvmills is offline
Greg,
Mel may have touched on something earlier that is a factor, that being weighing the airplane level. IIRC from my time as the tenant in your hangar, its not quite level. If the scales check out and the method (roll on or lower on) doesn't make any difference, try finding a more level spot (come on over), or weigh it tail in, then nose in. Just trying to help ya think it through.
Bob
PS: Cool new avatar, by the way!
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
