Apologies if you already knew this, but it was an 'ah hah' moment for me when I learned about it:
Additionally, the ANLs (limiter) or fuses for each alternator should be closest to wherever they tie into the battery, not closest to the alternator. The reason for this is that the battery is the source of electricity non grata (unwelcome current) if something were to fail in the alternator, for example, a shorted diode, or the wires leading to it.
-Jeff B.-
Albuquerque, NM
RV-7A (Preview Plans Stage), VAF# 1149
Assisting/designing panel for flying RV-6A
