Air vent placement
Hi All,
As part of a panel upgrade I'm cosndiering moving my air vents from the "standard" location to higher up on the panel. I've seen a couple installations done this way but far more in the traditional location.
Aside from the obvious routing of the vent tubing, is there anything else I'm failing to consider? Anyone put them there and then regretted doing so?
Thanks in advance!
Craig
Craig Bennett
321GT Flying RV6
2018 dues paid, how about you?
