Old 04-09-2011, 04:43 PM
SeanB's Avatar
SeanB SeanB is offline
Default DJM Tailwheel
Is anyone using this tailwheel? : http://websites.expercraft.com/sblai...y&log_id=53693
I bought this one through Van's and I see it for sale elsewhere.
The archives indicate early models peeling away from the wheel. I wonder if anyone has used the same product after DJM switched vendors and has been able to get some good time on it to reestablish confidence.
I really like this tailwheel, but don't want to worry about it.
SEAN BLAIR V7
Colorado Springs, CO
http://www.mykitlog.com/sblair
2020 VAF SUPPORTER
Old 04-09-2011, 06:48 PM
RV6_flyer's Avatar
I installed one last month. Will let you know after I have more time on it.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-09-2011, 08:37 PM
flynwest flynwest is offline
Default tail wheel
I had one peel off on the way to OSH used drill screws to hold till I got one @ OHS. I now have a new improved one seems good so far about 30 hours.
Old 04-09-2011, 09:18 PM
SeanB's Avatar
Dan,
How long did you use the first tailwheel before it failed?
Also, when did you purchase the new one?
Gary,
I'll be interested to see how yours works. Please let me know.
SEAN BLAIR V7
2020 VAF SUPPORTER
Old 04-09-2011, 11:39 PM
gciampa gciampa is offline
Wink
I purchased and installed one last Oct, 2010; I have about 60 hours on the plane since that time *without* any issues.
The stock Vans tail wheel bearings exploded on my, so, I purchased the DJM version.
Gary
Old 04-10-2011, 06:17 AM
AirbusPilot AirbusPilot is offline
I bought a DJM tailwheel two year ago, last week it failed after one year flying and 190 hours, I want to get a new one, but I have not been able to contact DJM through VAF message or mail
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 04-10-2011, 10:36 AM
AX-O's Avatar
AX-O AX-O is offline
Just talked to Dayton (owner of DJM), he is about to go flying. He told me he has not been online the last few days. He said he would get in touch with you when he returns from flying.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 04-11-2011, 02:28 AM
Thank you
Fernando Abasolo
Santiago Chile
VAF #2056
EAA Member 774981
Old 04-11-2011, 07:29 AM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Hi Fernando
Can you send me a PDF of your receipt so I can determine when your tailwheel was produced? Did the rubber peel off the aluminum? What was the nature of the frailer?
What I have been doing is just replace the tailwheel. I will also need a mailing address to send your replacement and I will need the old one back. Sorry for any unconvinced
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
Old 04-11-2011, 08:55 AM
SeanB's Avatar
Default How do I know?
Hi Dayton,
Is there a way to tell if the DJM Tailwheel I purchased from Van's 10-2010 is the improved version or not? I wonder if they had some of the older ones still in stock or if they were all replaced at a certain point.
Also, do you have any data on the improved version not seperating, or does it still happen on occassion?
SEAN BLAIR V7
2020 VAF SUPPORTER
