Old 04-07-2011, 02:32 PM
avengingangel avengingangel is offline
Default 540 engine owners
What starter and battery are you using? How well does it crank the engine?
Harmon Rocket II "the rockin bird"
Old 04-07-2011, 02:41 PM
vic syracuse vic syracuse is offline
Super Moderator
PC925, and I think it has the NLS starter on it. It is a Mattituck Red Gold. You might ask Mahlon.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 04-07-2011, 02:44 PM
Kahuna's Avatar
Kahuna Kahuna is offline
This question can not be answered when phrased this way.
Differences in compression, prop, wire guage, battery distance, typical OAT, etc have far more to do with cranking than the actual battery or starter used.
Perhaps if you could provide some of the information above we could give you some useful answers.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 04-07-2011, 04:06 PM
I just want to know what battery and starter people are using in an rv related aircraft right now that's all. if you have the battery in the tail or high comp pistons then mention it. and just make it a reasonable temperature. no reason to make this real complicated right now
Old 04-07-2011, 05:25 PM
Ron B. Ron B. is offline
We have the Sky-tec high torque inline and two PC680 batteries on the firewall. We are using #2 wire. We see a small increase in torque if we use both batteries for startup but the IO-540 turn quite well with one battery. We have two batteries for redundency.
Ron
Old 05-14-2011, 06:11 PM
Lan Vinh Do's Avatar
Lan Vinh Do Lan Vinh Do is offline
Default 925 and skytec nl
I just change from a skytec lsx to a nl. I have a io 540 with odyssey 925 in the back. The lsx had some problem. It hesitate on compression. I have a mt 3 blades. It never fail to start but frequently need multiple attempt with some that stop on the compression. The engine only had 150 hre.
The new nl don't hesitate at all. I made a good choice.
Lan vinh do
Rv10 c-gmce
Old 05-16-2011, 10:29 AM
mine works perfect too.
Old 05-16-2011, 12:11 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default IO540C4B5
Fresh overhaul, good compression --- using Skytec High Torque and Concorde RG-35A --- believe me, they get a good workout trying to hot-start that D*&%^ engine!!
Old 05-16-2011, 01:19 PM
lol, I know where you're coming from on that one. I think that's how I did my starter in last year. d*^%F$$*&$ hot start.
