Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 04-07-2011, 01:26 PM
SquishyOleo SquishyOleo is offline
Default Whirlwind GA200L Ground Adjustable Prop
Hi All - I'm looking at using a Whirlwind GA200L for my IO-320 powered RV-9A and was wondering if anyone who's using or has used it could provide some opinions on that propeller.
Thanks!
Mike
RV-9A Tip-Up
IO-320-D2A
http://www.mikesplane.com
Old 07-01-2011, 11:37 AM
MS19087's Avatar
MS19087 MS19087 is offline
Default Any update here?
Anyone using the WW FP prop?
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 07-16-2011, 09:08 PM
MS19087's Avatar
Default Guess no one is using the WW GA prop?
No reply here yet - does this mean no one is using this prop on an RV?? Curious how you like it - numbers?
Thanks!
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 07-17-2011, 01:16 PM
foka4 foka4 is offline
Default On a 4
I have 30 hours on my -4 with a GA200L. I don't have anything to compare it to, but it's light and performs well on my 150 HP O320. The matching spinner is very high quality.
Pitch adjustment is a little tricky with the tools and instructions provided, but it's doable. I have flown in some rain (and plan to fly in a lot more), and with the nickel leading edges, the finish is unscathed.
Looks great, too!
M
Old 07-18-2011, 10:06 PM
BASE1127 BASE1127 is offline
Do you have a 12 or 13 inch spinner on your -4? I was looking at buying a WW ground adjustable prop about two years ago, but they only made a 13 inch spinner at the time and I need a 12.
Eric
RV-4
Senior Parachute Rigger
Old 09-23-2011, 09:03 AM
CGVFR CGVFR is offline
do you have any numbers like rpm, speed wich altitude it was done. also rate of climb would be appreciate . i have an rv4 and looking these prop formy next chrismast present!
Michel
Old 09-23-2011, 10:03 AM
MS19087's Avatar
Default I will post some numbers soon
Installed this prop on my io320 equipped rv9a. Very happy so far. Some install issues I will report on later. However in the end all is well. Performance is very nice. Able to pick up several knots and not be limited to 2600 rpm. Also looks really nice too.
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 09-23-2011, 10:17 AM
N941WR's Avatar
N941WR N941WR is offline
Has anyone installed this prop on an O-360 yet?
If so, did they solve the issue with the mounting lugs/bolts?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-23-2011, 10:21 AM
cln1owner's Avatar
cln1owner cln1owner is offline
Interested in what "Install Issues" you had, since I'm very close to mounting mine.
What mounting lug/bolt issues?
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
"If you think you can do a thing, or think you can't do a thing, you're right." -- Henry Ford
Old 09-23-2011, 10:50 AM
N941WR's Avatar
Read the 5th post on this thread for details.
Bill R.
SC86 - Easley, SC
