Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 04-06-2011, 09:05 PM
Wesael's Avatar
Wesael Wesael is offline
Default Firewall GPS Antenna
Has anyone tried mounting there GPS antennas along with XM weather antennas on the firewall like Van has it done on the -12?
I would be interested in pictures of instaltions and any noted problems with satellite reception.
Weasel
RV-4 715hr Sold
RV-10 "School Bus"
I have changed my User Name to the correct spelling as it became availible. Please direct all correspondence to Weasel
Old 04-06-2011, 09:34 PM
D-Dubya D-Dubya is offline
Default It's been done
Have seen several successful installations putting the Garmin 430 "teardrop" antenna under the cowling. When I asked some of the guys at SteinAir about the heat affecting the antenna, they said it would not be an issue.
Some I've seen have been mounted to a bracket attached to the firewall, and some have been attached via U-bolts or Adel clamps to the engine mount. Just make sure you have it high enough so that the firewall can't obstruct the signal.
Not sure about the XM antenna, but someone else may chime in.
David Welsh
Beaumont, TX
RV-7 N413WD
Old 04-07-2011, 05:05 AM
pierre smith's Avatar
Default We had both antennae under the cowl...
...on my buddy's -4. It was also painted silver but it received very well.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-07-2011, 07:35 AM
Brantel's Avatar
Brantel Brantel is offline
Tons of people have done this long before the RV12. Works fine.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-08-2011, 02:37 PM
Wesael's Avatar
Default Thanks
Thanks for all you responses!!!
Great Info!
Weasel
RV-4 715hr Sold
RV-10 "School Bus"
