Originally Posted by ccsmith51
I found two FS numbers for Insignia White:
FS 37875
FS 37925
here:
http://www.fed-std-595.com/FS-595-Paint-Spec.html
I also found this on a Warbird forum:
Insignia Red FS # 31136, PPG DCC (Concept) # 74720
Insignia Blue FS # 35044, PPG DCC (Concept) # 16017
Insignia White FS # 37880 (?), PPG DCC (Concept) # 98043
HTH a bit...
It looks like these guys say it's the FS 37875 one (FS 17875 is the same in gloss), and reference a MIL-spec. They also give a lot of names associated with various colors -
http://www.milspeccoating.com/Federa...olors-s/41.htm
Insignia White, ANA 511 (Insignia white 17875 matches color of MIL-E-1115, formula 30)
That color is also the modern NATO white - from the Fed Std 595 document
International Standardization Agreement: Several colors listed in this standard are
the subject of international standardization agreement, MAS Army 440, 7 December
1987, NATO STANAG 2321, Edition 4. When there is a change, revision, or
cancellation of this standard which will affect or violate the international agreement
concerned, the preparing activity will take appropriate reconciliatory action through
international standardization channels including departmental standardization office, if
required. The following colors are covered by the above agreement:
i. Silver/ aluminum 17178
ii. Brown 30117 or 30140
iii. Red 31136
iv. Light Red 31158
v. Yellow 33538
vi. Light Green 34558 or 34449
vii. Dark Green 34108
viii. Light Blue 35109
ix. Gray 26231
x. Black 37038
xi. Violet 37100
xii. White 37875
You can buy certified color sample chips here quite cheaply stright from the govt. ($5 each)-
http://apps.fas.gsa.gov/pub/fedspecs...5CStandard.cfm
But last time I tried they did not have a lot in stock.
