04-04-2011, 02:07 AM
RV-9A Help on the empennage fiberglass tips?
OK I,am ready for the installation of the tips. Any videos out there or words of Wisdom? What to buy and from whom? Foam or Balsa wood with glass cloth? Thanks Guys
Ron in Oregon
04-04-2011, 07:13 AM
Ron,
Sounds like you are describing installation of the rib in the HS tips. After trying styrofoam and fiberglass (which absolutely doesn't work - the styrofoam melts - my first experience with fiberglass), I ended up fabricating a piece of 0.032 Al to fit this and epoxying it in place, then filling around the edges.
greg
Greg Arehart
N 7965A
04-04-2011, 09:10 AM
Ron in Oregon
Here's a recent thread on the subject that might prove helpful:
http://www.vansairforce.com/communit...ad.php?t=68191
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
04-04-2011, 09:20 AM
VAF Moderator / Line Boy
Originally Posted by Greg Arehart
Ron,
greg
Louise can chime in, but she just used the pink foam from Home Depot yesterday to do bulkheads in the empennage tips, and it worked fine with the West Systems Epoxy. (I have had white styrofoam melt away with Epoxy - maybe htat's what you tried Greg?)
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
04-04-2011, 09:28 AM
Yep, white styrofoam melts and makes a serious mess when used with epoxy!
greg
Greg Arehart
N 7965A
04-04-2011, 09:54 AM
I just went through this on my -9A. I used aluminum plugs and micro and they came out pretty nice.
Photos and writeup are on my web pages.
04-04-2011, 06:39 PM
I had some blue 1/2" foam which I trimmed and epoxied in place, filling in the gaps with micro. I then covered with fiberglass cloth bonded with epoxy, trimming along the ege. A few coats of micro and some sanding made a very smooth surface.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
04-05-2011, 12:24 AM
I want to say thanks to Bruce,Jeff,Greg,Louise,Paul,Rick and Roy Thoma. These were the two Ideas (metal plate and foam ) backed up by using epoxy and micro and cloth to get a nice blend in either of the end pieces. I'am on my way to order the list of items by Roy. Sounds like Aircraft spruce is the first item of the WEST SYSTEMS material.
Thanks for all your help.
Ron in Oregon 9A QB
04-05-2011, 02:15 PM
West Systems is also sold at WEST MARINE in Portland. I love being able to pick up all my WEST SYSTEM stuff without worrying the box will be sticky when it arrives.
1176 N Hayden Meadows Dr
Portland, OR97217-7546
Jason Hess
N777JH - Reserved
RV-7 - Builders Log Tail complete, wings nearly done, starting fuselage!
RV Factory - Complete sans floor coating, Slideshow Here
People are not excellent because they achieve great things; they achieve great things because they choose to be excellent.
Gerald G. Probst, Beloved Grandfather, WWII B-24 Pilot, Successful Businessman
04-06-2011, 01:50 AM
Thanks Jason, I maybe up in Portland later this week after all. My friend Roy said to get 105 level and it looked good on his 7A. Is that what you used? Ron
