Old 04-04-2011, 02:03 AM
ron sterba ron sterba is offline
Smile RV-9A LOOKING TO buy Rudder STOP
Not sure about the material but its a bar of hard nylon or something. Maybe UTHWM, Any clues where I could buy it or why I should not? Sounds like a good thing. Just finished the mounting of the Vert,Hori,Rudder,Elevator,trim Tab. Ron in Oregon
Old 04-04-2011, 07:14 AM
Greg Arehart's Avatar
Ron,
The internal rudder stop is sold by CraigVince (I believe) on this forum. The external (original Van's) stop is a piece of fabricated Al angle.
greg
Greg Arehart
N 7965A
Old 04-04-2011, 07:24 AM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Default Internal Rudder Stop
Yes, Craig had taken up the project of making the internal stops. He'll also send you the drawings if you would like to make them yourself.
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
Old 04-04-2011, 07:28 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Quick & Easy...
You can get one right here...
http://www.flyboyaccessories.com/sto...roducts_id=409
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 04-04-2011, 09:03 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
There was a 7A camped next to me at SNF that went through the storm. The only damage was to the rudder. The internal stop didn't stop the rudder from getting a hole on either side from the corners of the elevators. Lots of variables in that situation.....very high winds and no gust locks are biggies. Just sharing what I saw.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 04-04-2011, 09:22 AM
islandmonkey's Avatar
islandmonkey islandmonkey is offline
I have heard that because of the extra leverage and moment on the rudder when using the internal stop, damage is more likely if gust locks are not used and the rudder goes slamming into the internal stop.
This is only what I have heard and needs to be justified by people who may have found out the hard way.
Anthony Johnston
Brit working in Zurich, Switzerland.
1500 hour pilot and ex instructor and examiner.
RV-4 s/n 4572 Emp Kit.
RV-3B s/n 11460 Emp Kit. (In storage).
Anthony's RV-4
Old 04-04-2011, 09:46 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Here is Craig's contact info.
http://www.vansairforce.com/community/member.php?u=4499
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-04-2011, 10:53 AM
Flying Scotsman Flying Scotsman is offline
What extra leverage? What extra moment?
Both internal and external stops should result in the same throw, from the same hinge-line, and the stops are both located essentially in the same plane or nearly so (in one case, the stop is the surface of the spar, and in the other, a bar that extends out from nearly the same plane as the surface of the spar).
The moment of the rudder is also the same, regardless of type of stop.
I would guess that either one, with no lock, may result in damage from a sudden, violent slamming of the rudder to one side and the forces on it...both a momentum as it suddenly stops, and the end flexes as it continues in the direction of motion, plus perhaps a bending/twisting due to wind loads.
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 04-04-2011, 11:33 AM
The distance from the hinge to the point where the rudder stop arrests the movement of the rudder gives the moment. I would imagine that with the internal stop that distance is shorter than with the external stop. I could be wrong and I am prepared to be corrected, but in a nice way!!!
Anthony Johnston
Anthony's RV-4
Old 04-04-2011, 11:40 AM
Mike S's Avatar
Senior Curmudgeon
I believe the term for distance is "arm", and when multiplied by the force, the product becomes "moment"
Nice enough
Mike Starkey
VAF 909
Rv-10, N210LM.
