Cutting the Rudder Tip Fairing
First of all I'm at work and I don't have my build docs with me so excuse any mis-naming of parts.
I'm wondering what the best way others have found to trim the rudder fiberglass. I've heard of using a small abrasive wheel on a dremel tool, and I saw that Van's sells an abrasive wheel that can be used on a die grinder to cut fiberglass. The abrasive wheels that I found for the dremel are only about an inch in diameter so that seems pretty small to cut the full length of rudder tip. Although it might work well for cutting the required notch for the rudder horn. Just wondering what technique others have found the works the best.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
