Old 03-30-2011, 05:04 PM
pvalovich pvalovich is offline
Default Engine Tests
First off, I must admit to being somewhat challenged regarding engine construction, operations and performance. However, I do want to do a thorough engine data gathering drill on my 3rd flight - after exploring limited handling qualities regimes on the first two flights.
Vans chapter 15 flight test discussion just addressesgeneric engine cooling checks. Other documents just say to monitor and record oil pressure, oil temps, fuel pressure and CHTs from 55 to 75 percent rpm.
Does anyone have a systematic approach to doing so? What about throttle and mixture considerations?
Old 03-31-2011, 05:43 AM
pierre smith's Avatar
Default Hi Paul...
....what type of engine gauges do you have? If it's a digital one like the Dynon 120, it sure makes things much easier.
Also always record the OAT at the beginning of each test so that you will later be comparing apples to apples and you'll be able to see the relationship to oil and CHT temps for a given OAT.
Recording EGT's will also change,
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-31-2011, 07:26 AM
Default Engine Info
Sorry - should have included the imortant stuff:
RV-8A N192NM
New Aerosport IO-360, 180 HP
AFS 3500 Engine Monitor
