It should not greatly matter (after all, you have those big gaping holes at the hinge bearings letting water in forward of the spar anyway). If you have primed the skins, even water wicked into the joint will not cause a problem (and water can wick against gravity if the joint is tight).
Without the RV-7 plans in front of me, I can't verify your statement that there is a 'shorter' and 'longer' skin. On the -10 and -6 there was no difference and so the top skin went over the lower on my projects. I would assume that this would work in the -7 but perhaps -7 builders can tell you for sure. If you can, that's what I'd do for extra piece of mind.
EAA Technical Counselor #5357
