Old 03-29-2011, 10:52 PM
HighSchoolBuilders HighSchoolBuilders is offline
Default AN426 instead of AN470... structural issue?
Hi All,
I made a mistake of countersinking a component that calls for AN470 (namely FL-706B to FL-704 on the flap assembly). The countersunk part is 0.125" thick so it's well within limit of thickness for countersinking. However, the shop head will now has to be formed on the thinner material (0.025") of the FL-704 end rib.
1) Will I be jeopardizing the structural integrity of the assembly if I went from AN470 to a AN426?
2) If not, will it be a problem if I form the shop head on the thinner material?
3) if yes, will fabricating a reinforcement plate with a 0.030" or thicker material help, to allow the shop head form on the thicker material instead of straight on the thinner rib skin? (Sandwich the 0.025" material with 0.125" and 0.030", with shop head on the 0.030" material)?
Many many thanks for your input! The manual says "the flaps are the easiest control surfaces on the RV8/8A to build"....and I managed to screw this one up.
Cheers!
Hank
Hank Cheng
RV8 Super Slow Build Kit
Titan IOX360, Catto 3 Blades RV prop, Full Dynon everything + Garmin GTN650
First RV in Hong Kong
First Homebuilt aircraft registered in Hong Kong "B-KOO"
Completed RTW journey in 2016
Built with a group of High School Students
Aircraft donated to the Hong Kong Science Museum
In memory of Michael Tam
Old 03-29-2011, 11:01 PM
GAHco's Avatar
GAHco GAHco is offline
Question Maybe you will like this?
Originally Posted by HighSchoolBuilders View Post
Hi All,
Cheers!
Hank
You may be able to dimple the thin skin, countersink the thick piece to accept the dimple, and finally form the shop head on the non countersunk side. This should maintain an equivalent strength for your structure.
Best wishes.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 03-29-2011, 11:09 PM
Unfortunately, the piece i countersunk is unidirectional, I already countersunk the "outside", which left me no choice...
Hank Cheng
Old 03-29-2011, 11:44 PM
RV6AussieNick RV6AussieNick is offline
Default reverse the rivet
you can install a uni head rivet on the thin side and form the tail in the countersink. Rule of thumb is head on the thin side, tail on the thick side, if you try to form the tail on the thin side the material will pucker up around the tail.
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
Old 03-29-2011, 11:49 PM
What if I put a thick piece of material on top of the thin material? Will that be okay?
Hank Cheng
Old 03-30-2011, 12:15 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
The shear strength of the two rivets will be identical.
Try it and if the thin skin side doesn't wrinkle/pucker you are good to go. If you have a good 1.5D x 0.5D shop head you will have no loss of strength.
If it does wrinkle, remove the rivet and try a doubler...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-30-2011, 03:40 PM
bret's Avatar
bret bret is offline
Look at how you do the rudder T.E. ?
Old 03-30-2011, 04:52 PM
Thanks guys for all the quick response!
No wrinkle in my case, good to go
Thanks!
Hank
Hank Cheng
