Old 03-27-2011, 06:44 PM
mbetti mbetti is offline
Default 0320 constant speed
Ok, I changed the title from my core one. I would like to convert this engine to a constant speed prop. E2C 0320 from a Musketeer. I removed the front plug and there is no rear plug presently, just a cross drilling tube. If I was to send this crank to a rebuilder, could they rear plug it? What would be a good model code to follow, since this engine isn't listed for conversion. I supose there also are modifications to the case to make this happen too?
Mike
Mike Betti
Old 03-27-2011, 08:07 PM
RV6_flyer's Avatar
Too many things to look for to list in this post.
Start with Lycoming Service Instruction SI1435. It is available on the Lycoming Web Site. I have it linked above directly to the Lycoming web site.
Remember you need the accessory case machined to accept a governor drive adapter. The crankcase needs to have the correct bearing in the nose and a port on the right hand side of the engine in front of cylinder # 1.
Hope this gets you started down the road on what is needed.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
