03-21-2011, 05:52 PM
Rivet Strength
Long story short, I had two rudder horns. So I decided to find out how strong the little 3/32 rivets are. It was very unscientific and the method used to break the part created a stress point that's unrealistic of actual flight stresses.
One person held the rib while I pulled as hard as I could on the skin and this was the result.
The first one pulled through with quite a bit of difficulty, and the second one just ripped off. Both of them took quite a bit of force.
Looks like it got shot with a .22
Looking at this sure gives me a lot of confidence in the strength of a dozen 3/32" rivets all in a line.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
03-21-2011, 06:29 PM
...and that was in the peel direction, the weakest direction.
If you had just pulled instead of lifting the end, and loaded the rivets in shear you would have needed a lot of power assist...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-21-2011, 06:56 PM
When I experienced wing flutter in my Moni Motorglider, the wing skin was ripped off very similar to your test. The rivets remained in tact. The wing skin was .020 2024-T3. The flutter was violent enough to break the ribs from the rear spar at the fuselage and tore the aileron almost in two.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
03-21-2011, 08:10 PM
Jeez Mel, what kept you from being a ghost?
Actual repeat offender.
03-21-2011, 08:21 PM
Fortunately I was close to the ground. I got the airplane slowed down about the time I got into "ground-effect" and the flutter stopped. I landed "on the runway" and taxied up to a very shocked crowd. They said they could see the wing-tip oscillating up and down at least 2 feet.
I actually have a letter from John Monnette in my file that claims the cause of the failure was because I used solid AN rivets instead of the SS pop rivets called out in the plans.
03-21-2011, 08:31 PM
Originally Posted by Mel
<snip>
Ummm...yeahhhhh...riiiggghhhhttt. And if you believe that, I've got some ocean front property in Montana to sell you.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
03-21-2011, 08:53 PM
His reasoning was that the AN rivet is not as strong as the SS pop-rivet in tension. This fact is true; However, the rivets did not fail. The skin tore from around the rivet heads.
Of course his main reasoning was, "You deviated from the plans!"
03-21-2011, 09:40 PM
Scary
I'm sincerely hope I never see this on my RV8 once it's flying. My little experiment distroyed enough airplane parts for me. Interestingly, I could not tear the other side, no matter how hard I tried.
Scary to hear how distructive flutter is.
RV-8
Wings mostly done
83126
03-21-2011, 10:57 PM
it would be interesting to do the test with a perfect rivet, cleated rivet, slanted, offset, and all the common mistakes we all make.
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
03-22-2011, 07:58 AM
Dan Horton
RV-8 SS
Barrett IO-390
