shim lower engine mounts? carve out inside of cowl?
If you think it is just from engine sag, no harm in putting some large washers under your engine mounts. A pair of 1/16" washers will raise the prop flange about an 1/8" IIRC.
Depending on where your rub is, this may only get you a 1/16" to 1/8" increase in clearance. So if it is just rubbing a bit on start-up or shut-down, maybe that's enough change to make a difference. If the rub is worse than that, you should probably take more drastic measures. I try to maintain 1/2" of static clearance on everything in there, although the bottom of my ram-air/alt-filtered air housing is probably about 3/8" from the cowl.
What part of the engine is rubbing? What can be modified to improve clearance? If its the air box or snorkle, it can probably be modified to save your cowl paint.
But perhaps a better suggestion: The cowl is a honeycomb sandwich. You could gain about 3/16"-1/4" clearance by carving out the inside glass ply and honeycomb locally around the rubbing area, then glass in a patch of glass on the inside to seal it up. This is easy to do, will save your paint, and gets some needed clearance.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
