Old 03-21-2011, 02:04 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default fully developed turning stall with Dynon G-meter
Inspired to practice some fully developed turning stalls you can see the new SkyView G-meter pop up during the recovery... fun!
http://www.youtube.com/watch?v=zpX4bwbFMdE
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 03-21-2011, 02:33 PM
Brantel's Avatar
Brantel Brantel is offline
See why you don't want to do that on the base to final turn???
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-21-2011, 03:30 PM
Paul K Paul K is offline
Default Turning Stall in the pattern?
So, how many feet did you loose to full recovery?
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 03-21-2011, 04:06 PM
Jeff A's Avatar
Jeff A Jeff A is offline
Funny, it looks like your synthetic vision is showing the snow on the mountains.
....its not....right?
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 03-21-2011, 05:03 PM
Default turning stall...
The deep stall in the video was held to fully develop and is recovered in about 600ft (you can see the altitude tape going in 100s)... you will definitely need to do your own testing to get a feel for just what is going and how your aircraft responds but work up to it first... a developed turning stall is very close to ripping into a spin if you let it (the rotational rate will surprise if you), and it is not all that far from falling out inverted...
No snow in the synthetic vision... at least not yet! You are seeing the shading that is used to visualize elevation changes... it is more pronounced with steeper grading in mountain valleys.
Stephen
ORCA Flight
Race 771
margarita!
Old 03-21-2011, 06:11 PM
David Z David Z is offline
Default Related Experience
My friend tried that a couple times in a certified aerobatic airplane. On his first attempt, he just did a pseudo snap-roll. I don't know if he had too much power on or what caused it. Other than losing a few knots and shock on his part, nothing really happened.
On the next several attempts, the expected incipient spin was the result.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
