Old 03-21-2011, 10:55 AM
Cadstat's Avatar
Cadstat Cadstat is offline
Default Fuel tank inspecton cover
Some say to use the gaskets under the fuel tank covers T-708, some say just proseal metal to metal. I removed mine this week end and the original builder used gaskets and proseal. They weren't leaking but popped off easily.
How would you go back?
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
Old 03-21-2011, 02:21 PM
flion's Avatar
flion flion is offline
You can get new gaskets from Vans. I put a coat of Fuel-Lube on mine before I used them; I've replaced them when I re-plumbed the right tank for a return line and no leaks before or since.
EAA Technical Counselor #5357
