Old 03-21-2011, 08:50 AM
pvalovich pvalovich is offline
Default Exhaust - Engine Mount Clearance
I have an Aerosport IO-360 with Van's standard exhaust pipes. Clearance between the pipes and the engin mount is very tight. I can raise the pipes slightly by loosening the hose clamps and readjusting, but it seems that over time, they will continue to sag and eventually contact the engine mount.
I could make it a periodic inspection item - but I'm hoping for a permanent fix.
Has anyone used a piece of heat-resistent foam material attached to the engine mount as a buffer? If so, what material and where did you get it?
Also, there may be a concern that any exhaust pipe contact - even to buffer material - is a bad thing.
Any opinions - or better - factual info?
Old 03-21-2011, 03:31 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
I had the same concern. I have a RV-7A with TMX0-360. I now have 190 hours and the pipes have not sagged. The mounts hold them nice and snug.
I have seen engine mounts where the paint turned a slight burned color on some RVs in the field so I put a fire sleeve material that I pulled off of a fuel hose around the mount where the pipe got close.
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
