I had the same problem prior to flight.
It was showing right wing down - i.e. the horizon line was lower at the left.....
Before flight, I updated the firmware, still the same.
After 5 hours, it seems fine - weird !
However I now find that the Dynon altimeter is 200 feet out compared to the clockwork one which is correct to airport altitude at the beginning of the flight but 'catches up' after 30 minutes or so.
Who said these fancy gizmos were great
