Originally Posted by frewjm
DAR's & Engine builders may be able to help in this one.
We have a category in our regulations which allows for some homebuilt aircraft to be registered as a certified aircraft.
Accordingly my Lycoming O-320 E2A is a certified engine currently udergoing a bulk strip. In which I would like to instal the Lycoming PN: LW-15357 9:1 pistons from the H series engines.
In the certified world has such an installation Type Certificate been issued ?
Cheers
John
Team, from a previous posting by a most respected member the following data is extracted.
"9:1 compression is attained by use of the LW-15357 or equivalent, in the O-320, and it is generally accepted that you should use 100LL above with this engine. You should see around 164 HP at take off, with those pistons.
Good Luck,
Mahlon
Blue skies to all
