Old 04-12-2006, 10:06 AM
rtl_flyer rtl_flyer is offline
Default Baffle tube bracket
I am sure I have seen some alli tube with flange I could rivet to the baffle wall, and attach a cooling tube. I have found 1" at Aircraft Spruce but I am looking for 3/4" or 1/2". Like the heater duct to baffle but smaller.
Any links?
Regards Tim.
Tim
Vans RV7 -QB. Hampshire, England.
RV7 build diary (over 2000 pictures)- www.go-7.co.uk
My RV Flying site - www.GAPilot.com
Old 04-12-2006, 07:10 PM
Davepar's Avatar
Davepar Davepar is offline
The Vans solution for blast tubes is to just stick the blast tube through the baffle, I think secured with a cable tie. Report back if you find a flange. That would be a nicer solution.
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 04-12-2006, 09:44 PM
Ted Farmin Ted Farmin is offline
get your tubing and make a large alum. washer type piece to fit over it and
then find a Heli arc guy in your chapter or a shop and have them run a quick
bead around it, bracket made.
Old 04-13-2006, 03:11 AM
That would be great... but..... I am in the UK.
Driving at $7 a gallon to get a few parts welded more expensive than shipping made up parts in another country!
I am kicking myself... As I should have had a few parts in my pocket while I was at Sun N Fun. Great welding demo "could you show me on these parts?"
Sure I have seen a site with some on, but can't find it anywhere.
Although I could get 20-30 made up, could there be a market for them?
Tim
Old 04-13-2006, 06:43 AM
Tony Kirk's Avatar
Tony Kirk Tony Kirk is offline
Default Baffle Tube Flange
I picked up a piece of rigid aluminum tubing at the local hardware store (that fit the blast tubing I had), cut a piece about 2.5" long, drilled 6 holes around it about 3/4" from the end, cut to the holes with the band saw, and bent the six tabs out 90* and - voil? - a nice little hose flange. I riveted it to the front baffle for an alternator cooling blast hose mount. I used high-temp RTV to seal the flange to baffle gaps. The best picture I can point to right now is...
Tony Kirk
Van's Aircraft Tech Support
Building RV-7 (N777RV Reserved)
RV-6A N57TK (sold)
First flight 9/5/05...
Sold in 2011 after 725 hours of pure joy!
Old 04-13-2006, 08:21 AM
sf3543 sf3543 is offline
I have made them out of fiberglass and epoxy. You could use a wooden dowel, or something, as the plug and then remove it to form the tube and just make a flat lay up for the base. I made one this way for a 4" scat tube to my oil cooler that needed a special angle in it. I actually took the baffle piece and created a styrofoam mold and attached it to the baffle, then made the lay up over it. Worked great and looks good, too.
