All very good information and I appreciate this site very much. What's not totally clear is what tubing/wiring/coax might be run in the same space and not cause any issues such as RF noise. Bill, you used the two holes at the very aft of the rib for pitot/aoa. Did you run all other wiring through your conduit? The other question is it acceptable to enlarge that one hole far aft to 5/8 for a larger bushing and run AOA and other wiring through it?
Denis Sailer - Eastern Iowa
RV9A builder - Phase 2 (42 hours)
RV-9
