Originally Posted by Scott Will
What I did so far from my GMA-340 was to take the music and unswitched audio inputs to a terminal block so I can make whatever connections I want in the future. Good idea, Dan.
Just FYI, I'm
removing the terminal strip. It works if you're just connecting one or another audio source to the audio panel's input, but I have multiple music sources that need to be switched. I'm removing the terminal strip and adding this switch from Mouser:
1 10WA166 1 3.170 3.17
Lorlin Nylon Rotary
ROT 3POL 2-4POS SOL
It's a rotary switch that will select audio from one of
four sources. It isolates each source, so that only one may play at once through the primary music input.
I wired the switch with Mate-N-Lok connectors, made my ground loop isolator "modular" with male/female Mate-N-Lok connectors (so it can be swapped in or out of the circuit if I do or don't need it), etc.
This will be a muuuch cleaner setup than I have right now, which is basically all music sources "stacked" onto the terminal strip, and I listen to one at a time and disconnect the others. Ugh!
