Old 03-19-2011, 06:23 AM
pierre smith's Avatar
Default A few definitions...
Aviation language can be confusing to newbies, so I decided to start this thread and you guys can add to it as you see fit:
STATIC. Could be either the static air system for your instruments or static RPM. Static RPM is the most the engine will turn while stationary.
LOP: Fuel-air mixture "Lean-of-peak"...the engine is leaned to peak temps with the EGT gauge and then leaned further...LOP.
ROP: The engine is leaned to peak EGT's, then enriched 50-70 deg...ROP.
WOT: Wide open throttle operation, as in take-off and in racing.
EFIS: The new "glass" screens for Electronic Flight Information Systems, instead of the old round (aka "Steam" gauges).
EIS: Engine Information System...detailed engine monitoring with all engine parameters.
AHARS: Attitude and Heading sensors for the EFIS.
RNAV: Usually an approach to an airport using the GPS, WITHOUT vertical guidance.
LPV approach: Precision Lateral and Vertical GPS guidance during an instrument approach.
Others?
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-19-2011, 09:10 AM
jjconstant's Avatar
jjconstant jjconstant is offline
Default great idea Pierre
CAVU: clear and visibility unlimited
GADAHRS: same as AHARS but with GPS and something else as part of the black box...
MAP: could be a chart or manifold air pressure
MAG: could be a magneto or magnetometer
Slightly different than an acronym, but on the builder instructions, on parts with an "L" the "L" can stand for
Left, Lower OR Longer. Sometimes it's not obvious!
Keep 'em coming
Jeremy
Old 03-19-2011, 09:12 AM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
What does ?iran? mean in reference to an engine or cylinders?
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 03-19-2011, 09:14 AM
Inspect and Repair As Necessary.
I like to see yellow tags. IRAN without that sometimes means a new coat of Krylon (tm).
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-19-2011, 09:21 AM
SmilingJack's Avatar
SV - Synthetic vision
WAAS - Wide Area Augmentation System
LNAV - Lateral Navigation
i.e. -
LNAV/VNAV approach mins are higher then LPV mins
EVS - Enhanced Vision (the stuff Mr. Horton fly's with in them Globals!)
John Mastro
RV-8
Old 03-19-2011, 01:56 PM
Mel's Avatar
Mel Mel is offline
Default Just to "nit-pick";
Originally Posted by jjconstant View Post
CAVU: clear and visibility unlimited...That would be "Ceiling and visibility unlimited".
MAP: could be a chart or manifold air pressure...That would be "manifold absolute pressure".
Words added to satisfy stupid rule!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-19-2011, 03:27 PM
Walt's Avatar
Walt Walt is offline
"Yellow Tags" can also mean a fresh coat of krylon, heres a link to some good info on "Yellow Tags" vs a "Maintenance Release"
http://www.amtonline.com/publication...ubId=1&id=1781
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-19-2011, 11:52 PM
jjconstant's Avatar
Thanks Mel! Now if only this were horse-shoes or hand-grenades I'd be "close enough"
Jeremy
Old 03-20-2011, 05:06 AM
Default I just had one...
....done on my turbine PT-6 in the Air Tractor. The gear reduction box and engine are going on 9,000 hours and this was the first gearbox IRAN.....aaaaand....it's going to cost near $50,000! A new gearbox runs north of $100K. The whole engine, new from Pratt @ Whitney goes for something north of $300K, so an IRAN of $25,000 is a great deal.
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 03-20-2011, 06:42 AM
flion's Avatar
flion flion is offline
Have we got room for non-official definitions, such as TLAR (That Looks About Right)? That used to be used to refer to a open bomb-sight system for ground attack aircraft in WWII (I saw it in a Bob Stevens cartoon, no less) but I've heard it used in reference to building.
EAA Technical Counselor #5357
