Old 03-18-2011, 06:29 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
Default Master Cylinder Problem
My RV-8 has dual Matco master cylinders. Each master has its own mini reservoir. I did a swap out on all the O rings in the system and filled the lines with DOT 4 fluid today, from the bottom up.
Left brake works fine, nice and firm. The right brake will sometimes be firm and other times will fade to the floor. After the fade, if I depress the pedal again it will squirt brake fluid from the breather cap on the reservoir.
Has anyone seen this before?
Thoughts or suggestions appreciated.
Tks,
Mike
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Pmags, CS
Bridgewater, MA
KPYM
Old 03-18-2011, 06:41 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Make sure the piston is returning all the way to the top, also make sure your totally air free on the problem side-----what you describe could be either from the sound of it.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-18-2011, 06:53 PM
9GT's Avatar
9GT 9GT is offline
If you have the old style Matco (Parker) parking brake valve,,,,they had a tendency to leak internally trought the check valve. We had the exact same problem on the Cozy MKIV and replaced the old valve with a new style one. It solved the problem for us. FWIW
David C.
Howell, MI
Old 03-19-2011, 10:41 AM
aerhed aerhed is offline
GT's right. Sounds like the compensator is stuck.
Actual repeat offender.
