Old 03-18-2011, 03:19 PM
Brantel's Avatar
Brantel Brantel is offline
Default Beam width when using H3 bulbs instead of H3C???
I flew as PIC last evening for the first time at night since 1988.....all went well.
The new HID bulbs I installed in my Duckworks rectangular fog light reflectors were H3 bulbs and the originals were H3C.
I had plenty of light last night but I would like a wider beam...
My question is will a H3 make a wider or narrower beam in a reflector made for an H3C ?
If I can get a wider beam with H3C, I will make a spacer to move the H3 aft in the reflector....
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-18-2011, 04:04 PM
GregM GregM is offline
Hey Brian, Can't help you on the bulbs, but I was wondering if it was you that flew over Oak Ridge last night headed towards Morristown? I was out in the driveway sanding on my wheel pant fairings when a RV flew overhead scooting along at a good clip. It provided the motivation to finish sanding. However, after priming this afternoon, I THOUGHT I had all the pinholes filled!
Greg Morgan, A&P
RV-8A, Phase 1 @ KDKX &
TN08
Oak Ridge,TN
Old 03-18-2011, 06:47 PM
rocketbob's Avatar
Why don't you just make a spacer so that the center of the bulb is at the same place a normal h3 bulb is?
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-18-2011, 07:32 PM
RV8iator's Avatar
RV8iator RV8iator is offline
I had to make a spacer to move my H3 bulbs farther back into the reflector to make the beam narrower. I am using the rectangular reflector that came with the Duckworks. I made the spacer 1/4 inch and it focused the beam into an area about 6 feet wide at 20 feet in front of the wing.
If I just put the bulbs into the reflector the beam was probably 20 feet in diameter out about 20 or 30 feet in front. Much to dispersed to make any really usable light.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 03-21-2011, 02:04 PM
Brantel's Avatar
No that was not me. I was not that far West....I was scooting along though!!!
Brantel's Avatar
Thats weird...I have too much of a spot. I want to widen it not tighten it...
Old 03-21-2011, 02:05 PM
Brantel's Avatar
Thats what I will do if that will widen the beam. Looks like that would tighten it though which I do not want to do...
