03-16-2011, 12:02 PM
Catto prop question
During my build I have always expected to use a IO360 180 hp engine with a Catto 3 blade prop on my 7A. I recently fell into a great deal on a IO360 A1A 200 hp engine.
I still like the Catto prop but searches have not found anyone using it on a 200 hp engine. If any of you are using a Catto 3 blade on a 200 hp engine I would like to hear from you on performance etc.
Jim Kinsey
7A Finishing and Engine
AFS screens
IO360A1A, Catto 3 blade
N527K reserved
Donated thru 2018
03-16-2011, 12:23 PM
Rv8bldr has a catto on a 200hp -8 he built. Here's a post from him about his experience.
Kevin
03-16-2011, 02:03 PM
Jim, we ran one for 5years/500 hours...
...on our -6A and never regretted it.
If I had to do it again, I'd go with the two-blade because the cowl is a bear to get off with a three-blade....the two lower blades get scratched by the lower cowl hinges, even with the slot for the nosegear lengthened to its max.
Craig knows how to pitch the prop for your airplane/engine combo. He'll want to know what your preference is....max speed or a compromise between speed and good climb/ aerobatics.
We wanted max speed and he gave it to us.....better than Van's numbers by a bit!
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
03-16-2011, 02:12 PM
Forum Peruser
Cowl removal with Catto 3-blade and "non-A" RV
Originally Posted by pierre smith
..If I had to do it again, I'd go with the two-blade because the cowl is a bear to get off with a three-blade....the two lower blades get scratched by the lower cowl hinges, even with the slot for the nosegear lengthened to its max.
So, Pierre, are you saying that a non-nosegear (RV-6) with a Catto three-blade would not have the problem of scratching the two bottom blades? I realize yours was a -6A but just to clarify, I would like your opinion on the non-nosegear cowl removal with the Catto three-blade prop.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
03-16-2011, 02:16 PM
No problem with tailwheel.
The tail wheel gear does NOT interfere with lower cowling removal. I have never scratched my 3-blade Catto with the cowling.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
03-16-2011, 02:26 PM
There is a pattern shown in one of the RVators about 3-4 years ago that shows a cut out procedure in the front bottom cowl where the top overlaps the bottom behind the spinner area that makes removing cowling with a three blade a non-issue on (A) models. When assembled you'll never see it due to the overlap.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
03-16-2011, 02:38 PM
Uhhh, yeah, what I said
Still have the Catto prop and still love it. 400+ hours on it now.
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
03-16-2011, 02:46 PM
Forum Peruser
Thanks, Mel. I thought so, but I wanted to hear it from someone with that combination. I had forgotten about yours being a three-blade.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
03-20-2011, 09:56 AM
Two's company
Jim,
I tested the first 2 blade RV designed Catto on my RV-4 in 99'. Over time Craig helped me refine the design and several friends purchased 3 blades for their RV4's. I flew alongside many of them and overall I proved time and again the 2 blade outperformed the 3 blade in every aspect except smoothness. I have recently purchased a new Catto 2 blade for my RVX and will post the test data in comparison with it's current MT 2 blade.
Personally, I would go the 2 blade.
Smokey
03-20-2011, 11:20 AM
It has been done...
Hi Jim,
I had a Catto 3-blade paired with an IO-360 A1A on the RV7 I bought flying last year. Unfortunately, I only flew it for about 25 hours, half of which was flying the plane home from Michigan to Oregon, so I never got a chance to do good testing. Static RPM was low (~2150 if I remember correctly) and take-off performance a bit anemic for an RV, but the consensus from several RV builders was that it had more to do with airflow to the engine intake than the prop. The builder had placed the air filter flush with the sloped cowl versus in the typical horizontal induction location, and the theory is that there wasn't enough pressure. I also discovered recently that the CFM rating for the K&N air filter used was about 1/2 of what is needed for the IO-360. Craig was open to working on adjusting the pitch to help if necessary once I sorted out the air intake.
Sadly, before I could work out the problem, we found metal shavings in the oil at 1st oil change and the plane has been grounded since. Turns out the engine had multiple problems including a cracked crank, so I decided to replace it with a new 180 hp IO-360. Craig re-pitched the prop and added his new nickel leading edges. Hope to be back in the air soon.
Hope your experience with the engine you got a deal on is much better than mine!
bill
RV7A QB kit -- sold and now flying in S. Africa
RV7 purchased flying
"A pilot just bides his time until his plane can take him away again, into the air"
-- Jake Grafton (Stephen Coonts, Flight of the Intruder)
