Old 03-15-2011, 06:58 PM
vmirv8bldr's Avatar
vmirv8bldr vmirv8bldr is offline
Default IO-390 with SJ Plenum
Has anyone here installed a Sam James Plenum on an IO-390 and then mounted the large SW oil cooler? Looks like this is going to be a tight fit, and have to get the AFP spider reconfigured.
Appreciate any guidance, tips, hints, and especially pictures.
Thanks in advance,
Bart
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
Old 03-15-2011, 07:52 PM
Fastback8 Fastback8 is offline
Default I have the same problem with an angle valve I0-360
Dan Horton comes to mind and he designed his own plenum. Nice work too, I might add I am a Dan fan! Positioning with the larger engine? The larger Oil cooler works well on the right firewall. Place it in a horizontal position, down low. Use a 4" hose leading into a duct and make a gentle bend. (Make the duct like Dan H does here) http://www.vansairforce.com/communit...ad.php?t=44856
or use wood to make a form and clear tape, then lay the wet cloth, glass.
I would rotate the spyder upside down and that should give you the plenum clearance. Sam recommends this. Alternatively, cut-out a spyder hole (no pun intented) and glass a dome over the spyder to solve the clearance. Easy enough either way.
Good luck
Mike
Look good, FLY FAST
Old 03-16-2011, 12:08 PM
deene deene is offline
I used Sam's plenum on my '8 with a 390. Plenum fit after I split it, put a joint in the center (fore/aft), and added a bump (about 1/2" high) to clear the spider.
I've had very good results speed and cooling. I used a larger oil cooler mounted on the firewall and a 4" duct feeding it off #3.
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
