03-14-2011, 11:25 PM
Tip up hinge pin mod
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
03-15-2011, 01:19 AM
A very practical, if somewhat beefy solution. The only thing that jumps out at me is that it might be easier to grab ahold of it for insertion and removal if the flange of the angle were on the bottom rather than the top. It is a little awkward to reach under the panel in order to do this.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
03-15-2011, 01:47 AM
Great idea........ let's improve on it.
Rivet the nut plate vertical but add another to the left of it based on the picture. And install a allen bolt with about three nuts threaded down to the head to make a extended shaft to slide the pin out from the panel side.
The other nutplate is used to lock the slider in place with another screw when the pin is slid into position. It will be secure against the far side of the slot.....
03-15-2011, 06:31 AM
Beefy, yes
Yes it is a little beefy, I used what I had. It is still lighter than all that **** for the jettison mechanism.  No need to remove and insert it. The sub panel is slotted so the pins can be disengaged by simply loosening the screw and sliding it inward.
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
03-15-2011, 06:38 AM
Not enough room
Answered in quote
Rivet the nut plate vertical but add another to the left of it based on the picture. And install a allen bolt with about three nuts threaded down to the head to make a extended shaft to slide the pin out from the panel side. There isn't enough clearance to the canopy frame when closed to leave a permanantly installed handle of sorts. That is why I simply remove the screw and install a long bolt for leverage to slide the pin out.
The other nutplate is used to lock the slider in place with another screw when the pin is slid into position. It will be secure against the far side of the slot.....I actually considered the 2 screw thing, but it is overkill now!
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
03-15-2011, 09:21 AM
Great idea Don.
I did mine close to your solution. Because I needed space on the subpanel and didn't know how to weld this is what I did.
I used the pin and the rod as per the plans, but inserted them from the outboard side. I then secured the handle (rod) with an adel clamp into a plate nut attached to the rib.
I had hope that after riveting the forward top skin that I would never have to remove the canopy again. As it turned out I had the canopy off and on at least four times. I don't have access holes in the forward skin, which would have made this attachment system every easy to use.
You need to just get used to being on your back under the panel, as there are all kinds of work that will happen down there.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
01-31-2013, 02:33 PM
Originally Posted by Don Jones
I have been working to come up with something for the hinge pins on my tip up for a while now. With the center stack radios the jettison assy had to go bye-bye and I really hated the idea of the old bolt and nut thing. So the other night I was standing there pondering the problem, when snap, the other brain cell kicked in. It's so simple it's stupid! Here is what I came up with. Took the van's supplied pins, tig welded them to a couple of pieces of angle, slotted the sub panel for the retaining screw, riveted on a couple of nut plates and some umhv tape on the back of the sub panel and it was done. You can remove the retaining screw and install a long an3 bolt to help disengage the pin and no crawling under the panel to put on a nut! I guess I will find out how well it works when I dig the canopy back out in a few months.
What material are the pins made out of? If aluminum this implies AC/DC TIG system?
GH
01-31-2013, 03:45 PM
GH
The pin is steel as is the angle I welded it to. I used my tig machine to weld it, but it could be done with a torch or a mig welder easy enough.
By the way, this works terrific!
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
01-31-2013, 05:38 PM
What a good idea.....
You don't need two nutplates. What I see missing is a positive lock when the pin is slid in place. I would have the nutplate positioned against the opposite side of the slot when the pin is engaged. I would then have an AN3 "lightening" hole where your existing nutplate hole is and I could insert a Phillips screwdriver in it and slide the pin assembly open after I had removed the nutplate screw. Thanks for sharing...
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
01-31-2013, 06:04 PM
Actually it is really easy like it is. Remove screw that locks the assembly in place, install long an3 bolt for a lever of sorts and slide the pin. The screw hole in the panel is slotted so the pin can't come completely out. It slides back just enough to remove the canopy.
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
