Old 03-14-2011, 10:15 PM
CPSONE's Avatar
CPSONE CPSONE is offline
Default Extra hole in VS808PP
I ordered a replacement VS rear spar doubler from Van's as I thought I'd go without the lightening holes. Well Van's cuts the lightening holes for you now so that's ok. Problem now is there is an extra 1/8th hole in the doubler just above the second lightening hole from the bottom that's not on the plans. It seems to line up with where the bolts attach the rear spar to the fuse. Is this just an extra that you countersink and flush rivet (flush side against the fuse bulkhead or is it used later? I've looked on builder websites and no one has that extra hole...
Mike
RV-6 emp, done-sold,
RV7A QB. Passed pre-cover and sold!
Disclaimer: Everything I say can be presumed to be wrong. Don't try this at home.
Old 03-14-2011, 11:14 PM
bruceh's Avatar
bruceh bruceh is offline
It has been discussed in a couple of different threads here. Here is one:
http://www.vansairforce.com/communit...ad.php?t=38534
Bruce Hill
2020 VAF donator
Old 03-15-2011, 11:29 AM
CPSONE's Avatar
Default extra hole
Thanks for the reply.
I searched it in the forums but didn't find that thread.
Here's what Gus at Van's said this am:
"Nothing needs to be done. The hole can be drilled and used to cleco the VS to the fuse later on for temporary alignment before the bolt holes are drilled."
Vans
Mike
