Old 03-13-2011, 08:32 PM
Junglepilot's Avatar
Junglepilot Junglepilot is offline
Default Tip: Installing/Removing screws without boogering the heads
Those 8R8 screws [just for example] are very soft and the Philips slots get mangled pretty easy, especially if you use an electric drill driver and don't get a good set on them first, or their just too darn tight.
Do this:
  1. Get a tube of Permatex Valve Grinding Compound at auto parts store.
  2. Dab a tiny bit of the compound on the screwdriver tip
  3. This will help the driver tip to stay in the Phillips Head slot without slipping out whether tightening or loosening the screw.
Sandy Toomer
Commercial, Instrument, A&P
EAA: 1023750
Based Lanett, AL (7A3)
Auburn, AL
WAR EAGLE!
Old 03-13-2011, 08:54 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Good tips, and I'll add another - buy GOOD screwdrivers and/or bits. It is amazing how well a properly built Phillips can grip a screw!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-13-2011, 09:06 PM
vlittle's Avatar
vlittle vlittle is offline
Paul
Paul's right. Snap-On bits have gripping ridges that help, and some Craftsman screwdrivers have diamond dust coating the tip.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 03-13-2011, 09:52 PM
flytoboat's Avatar
flytoboat flytoboat is offline
A dab of toothpaste on the tip will help with stubborn screws also.
Don
VAF #1100, EAA864
-6A bought flying
Old 03-13-2011, 10:17 PM
Snowflake's Avatar
I've got a few good Snap-on Phillips bits too. They work great for removing Phillips screws. I don't use them for inserting, because I replace with Robertson or Torx heads...
Rob Prior
Old 03-13-2011, 10:39 PM
9GT's Avatar
9GT 9GT is offline
Better yet is to replace them all with 6 lobe drive (Torx) screws.
David C.
Howell, MI
Old 03-13-2011, 11:36 PM
RV7AV8R's Avatar
RV7AV8R RV7AV8R is offline
I bought some #6 torx SS screws and found they actually stripped out easier that the AN phillips head. Maybe the SS ones are just too soft. I was both surprised and disappointed.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
Old 03-14-2011, 07:50 AM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
Default German quality
Check out the Wiha brand screwdrivers at http://www.wihatools.com . They've supplanted my previous favorite brand Snap-On.
William Slaughter
Houston, TX
RV-8QB
Old 03-14-2011, 07:56 AM
Sid Lambert Sid Lambert is offline
I always put a rub of Boelube on the threads of new screws. There is no need for the threads to have that much resistance in the nut plate. If you just find ways for the screw driver to bite the head without easing the stress in the threads you will start breaking the screws off. This issue is a downside to having a cowling with no hinge pins but hundreds (feels like it) of #6 and #8 screws.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 03-14-2011, 08:09 AM
Rockyjs Rockyjs is offline
You can try ever so slightly tightening the screw to "break it loose" then remove it.
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
