Old 03-13-2011, 06:27 PM
Darren S Darren S is offline
Default Soft left brake pedal
On the first flight of the day the left brake pedal depresses quite a bit. When I release the pedal and then step on it again, it is much firmer. The right pedal doesn't do this so something is leaking somewhere.
I didn't build the plane so I'm looking for a little guidance before I hit the hanger tomorrow.
Is regular automotive brake fluid usually used ?
I suspect the left caliper. I think I'll look there first rather than the brake reservoir.
Darren
Old 03-13-2011, 06:30 PM
Mel's Avatar
Mel Mel is offline
Sounds like you have air in the left circuit somewhere.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-13-2011, 06:57 PM
Geico266's Avatar
Geico266 Geico266 is offline
If you can ask the old owner what fluid he used. Most aircraft do not use car brake fluid because it will harm paint, and absorb moisture. It would not be a good idea to mix them.
You will need to bleed the brakes from the bottom up using a pressurized system of some kind. (see link below) I made one using a 1 gallon garden sprayer filled will the red Mil Spec 5606. This of course is a subject of hot debate.
Brake Fluid Wars --------------> http://www.vansairforce.com/communit...highlight=5606
Brake Bleeder ------------------>http://www.aircraftspruce.com/catalo...leedertank.php
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 03-13-2011, 07:43 PM
Thanks for the help.
Bleeding the brakes is a two man job. I will try to find out what the previous owner used. If not I may have to drain out all of the fluid and start over.......... sheesh........I think I may wait till the annual in May since there isn't really a safety issue.
Darren
Old 03-13-2011, 08:12 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Actually it's quite easy to do as a one-man job. If you read one the threads posted above you'll see how.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 03-13-2011, 08:17 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Easy one man job from the top, takes about 15 minutes even with dual brakes.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 03-15-2011, 08:11 PM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Is it a Matco master cylinder unit? After you bleed the brakes, if the problem recurs you may need to use an overhaul kit to make sure the O-rings are okay (available from Van's). if that doesn't solve the problem then consider an alternative such as the Grove units. I switched years ago after having a similar experience, and have had no problems since.
Chris
Chris Pratt (2020 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
